Discussion topic: WiFi not working
Message posted on 18 Jan 2026 10:56 PM
WiFi not working
Message posted on 19 Jan 2026 04:34 AM
Re: WiFi not working
@MehmetParlak
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
