Discussion topic: WiFi not working
This message was authored by: Skyrfymf
WiFi not working
Our internet isnt working, we have orange colours showing on the box
Re: WiFi not working
@Skyrfymf
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
