Discussion topic: WiFi not working
Message posted on 27 Dec 2025 06:55 PM
WiFi not working
Hi, we just reset our router and our wifi is now not working. I have run a test, but it hasn't picked anything up, but still no WiFi.
i have two green lights and an orange light on
thanks
Chris
Message posted on 27 Dec 2025 07:03 PM
Re: WiFi not working
@Chrisscb
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
