Discussion topic: WiFi not working
This message was authored by: Smac73
WiFi not working
For over 24 hours now my WiFi connection is temperamental. One minute it's connected and within a few minutes it disconnects and will not even find my network. Would appreciate any advice. Some devices 'get connected again' quicker than others.
Re: WiFi not working
@Smac73
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
