Discussion topic: WiFi not working
Message posted on 19 Dec 2025 02:14 PM
WiFi not working
My WiFi is not working and the voice light on my router is blank. I have just plugged in a replacement router that was sent. This was sent as my WiFi was previously cutting out and the person on a call said I should replace the previous router.
Message posted on 19 Dec 2025 02:31 PM
Re: WiFi not working
@Ross100 You should re contact sky about it all explaining the replacement sky Hub has not helped with the connection and then they can work out what there next step will be, linked below about the hub lights.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Message posted on 19 Dec 2025 02:52 PM
My WiFi is not working either despite all the fixes suggested. Need Sky to sort it out their end!
Message posted on 19 Dec 2025 02:57 PM
@GF19 If you need sky, give them a call dial 150 from your landline if working or 150 if you also happen to have a sky mobile!
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
