Discussion topic: WiFi not working
Message posted on 06 Dec 2025 09:14 PM
WiFi not working
My WiFi is not working
Message posted on 06 Dec 2025 09:16 PM
Re: WiFi not working
@Chloem26
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
