Discussion topic: WiFi not working
Message posted on 27 Nov 2025 07:09 PM
WiFi not working
My sky intwent light won't go green or the voice light and ca t connect to WiFi
Message posted on 27 Nov 2025 07:13 PM
Re: WiFi not working
@Jp126
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 27 Nov 2025 07:54 PM
My Wi-Fi is not working too
Message posted on 27 Nov 2025 07:57 PM
The post above from @Daniel0210 applies to you as well.
