Discussion topic: WiFi not working
This message was authored by: kelz2345
WiFi not working
No WiFi for over an hour
Re: WiFi not working
@kelz2345
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
