Discussion topic: WiFi not working
This message was authored by: CPC1
WiFi not working
Internet has gone down
Re: WiFi not working
@CPC1
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
