Discussion topic: WiFi not working
Message posted on 26 Oct 2025 08:39 PM
WiFi not working
My WiFi has no internet
Message posted on 26 Oct 2025 08:46 PM
Re: WiFi not working
@Kd851
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again later).
