Discussion topic: WiFi not working
Message posted on 23 Oct 2025 05:06 PM
WiFi not working
WiFi isn't working, we have 2 green lights and 1 orange light. Everything looks good when I've ran checks on here however no connection to any of our devices
Message posted on 23 Oct 2025 05:27 PM
Re: WiFi not working
@Helen23101
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
