Discussion topic: WiFi not working
This message was authored by: Nicole0001
WiFi not working
My WiFi isn't working the the internet and voice lights are amber on my hub
Re: WiFi not working
@Nicole0001
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
