Discussion topic: WiFi not working
This message was authored by: Paris21
WiFi not working
Is anyone else having this problem where there WiFi isn't working
Re: WiFi not working
@Paris21
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are still having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
