Discussion topic: WiFi not working
Message posted on 16 Sep 2025 10:50 AM
WiFi not working
Our WiFi has always been poor, but now it is not working more regularly and for longer periods. We work from home so this is a huge problem
Message posted on 16 Sep 2025 10:58 AM
Re: WiFi not working
@Michaelb3
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
