1
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Lh30
WiFi not working
Hi,
Our wifi has stopped working and we have no internet connection but the broadband tests via Sky keep saying everything is fine. It was working before and we have not changed any setting or touched the wifi. We have tried turning it on and off but it is still not working, please help.
Lucy
Re: WiFi not working
@Lh30
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Lh30
