Discussion topic: WiFi not working
This message was authored by: Sophie32
WiFi not working
Not working
Re: WiFi not working
@Sophie32
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
