Discussion topic: WiFi not working
Message posted on 19 Aug 2025 10:52 AM
WiFi not working
Hi my WiFi seems to not be working this morning. Is there a problem. I have done a check on the app and it says everything is ok but it is not.
Message posted on 19 Aug 2025 10:59 AM
Re: WiFi not working
@Buffer1
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
