Discussion topic: WiFi not working
Message posted on 18 Aug 2025 10:01 AM
WiFi not working
My WiFi keeps going off and showing at red in the WiFi box, I've only been with sky a month, this needs sorting or I'm switching provider. Thank you
Message posted on 18 Aug 2025 10:03 AM
Re: WiFi not working
@Millie271
You aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Millie271 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
