Discussion topic: WiFi not working
This message was authored by: Daryl11869
Message posted on 15 Aug 2025 09:03 PM
WiFi not working
Back area of my property where I had to get an Ethernet cable installed and then sky connected a booster still not working. The booster intermittently disconnects. Seems to work through the week and then stops working on a week end.
Find out more
Message posted on 16 Aug 2025 07:52 AM
Re: WiFi not working
@Daryl11869 there is no obvious way an ethernet connection will work during the week and not at weekends. You will need to check if the connection goes via a switch if it does the switch needs to be powered for tge connection to work is somebody turing it off when they finish work on a Friday?
