Discussion topic: WiFi not working
Message posted on 07 Aug 2025 02:07 PM
WiFi not working
My WiFi isn't working, I've tested it when I log into sky and it says it's fine but it isn't. tried turning on/off and tried on my laptop, phone and Alexa and won't work on either
Message posted on 07 Aug 2025 02:24 PM
Re: WiFi not working
@Tia32
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
