Discussion topic: WiFi not working
This message was authored by: CharlotteRitchi
WiFi not working
Our WiFi is not working
Re: WiFi not working
@CharlotteRitchi
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
@CharlotteRitchi  If you mean your Brioadband isn't working first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
