Discussion topic: WiFi not working
Message posted on 15 Jul 2025 10:34 AM
WiFi not working
Hi, my WiFi keeps going off. I have to keep unplugging my router and then restarting it
Message posted on 15 Jul 2025 10:37 AM
Re: WiFi not working
@Emma458
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 16 Jul 2025 07:29 PM
I’ve tried the service checker it tells me there isn't a problem but this is happening daily, sometimes multiple times a day
Message posted on 16 Jul 2025 07:40 PM
@Emma458 in the reply @Daniel0210 sent you three links, how did you get on with the diagnostics, and when you have an issue the about lights explained what they are, that way you can pass any info back!
