Discussion topic: WiFi not working
This message was authored by: El23
WiFi not working
Hi. I've switched to sky a few months ago, and the WiFi started off well, now it's just not working.
I've now used all my mobile data. It says that it's connected, my devices show full WiFi, and a test said there's no problems.
ive tried all the troubleshooting steps too.
Re: WiFi not working
@El23
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Avatar for El23
Hi! Thanks for getting back to me.
I've run both of those tests and they don't seem to have any problems - none reported in area either.
I don't have a home phone, and when I called sky the automated service also only got me to do the tests.
@El23
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
