Discussion topic: WiFi not working
This message was authored by: George137
WiFi not working
For the past few days the WiFi box has got a flashing green light not a white light. I've turned it on and off a ridiculous amount of times. But when I check the signal on the sky app it says the connection if perfect but the WiFi isn't working.
Re: WiFi not working
@George137
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
