Discussion topic: WiFi not working
Message posted on 11 Jun 2025 12:29 AM
WiFi not working
My WiFi is not working! I have reset the box and have tried the service checker which is telling me everything is fine !
Message posted on 11 Jun 2025 03:58 AM
Re: WiFi not working
@Sarah475
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back up and running in the morning use this link to check to see if there are any broadband problems or outages nearby.
Message posted on 11 Jun 2025 06:06 AM
Message posted on 11 Jun 2025 07:49 AM
@ChimpM4ster the service checker does not run all the time and it cannot pick up disconnections until the hub fails to respond to a routine test request. In practice the lights on your hub tell you the current position see https://www.sky.com/help/articles/hub-lights-explained-start
