Discussion topic: WiFi not working
Message posted on 10 May 2025 03:54 PM
WiFi not working
Could you please tell me if there's an issue with my WiFi, it doesn't seem to be working
Message posted on 10 May 2025 03:58 PM
Re: WiFi not working
@DaveNorris
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
