Discussion topic: WiFi not working
This message was authored by: Rachel561
WiFi not working
No WiFi. Switched off and on twice router
Re: WiFi not working
@Rachel561
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Re: Haverholme
@Rachel561  Your duplicathe thread has been removed as you already raised the issue here, please don't create duplicate threads as this will simply duplicate answer and possibly cause more confusion.
