Discussion topic: WiFi not working
This message was authored by: Dharm2
WiFi not working
WiFi not working at today 18th Apri. Connected to hub but no internet. Randomly dropped multiple times since morning.
Re: WiFi not working
@Dharm2
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
@Dharm2
Your duplicate thread has been removed. No need for two.
