Discussion topic: WiFi not working
This message was authored by: Sophie410
WiFi not working
Wi fi not working
Re: WiFi not working
@Sophie410
Wifi or internet? Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
