Discussion topic: WiFi not working
Message posted on 03 Apr 2025 12:54 AM
WiFi not working
Message posted on 03 Apr 2025 03:21 AM
Re: WiFi not working
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down at 0700 use the below link to check to see if there are any broadband problems or outages nearby
