Discussion topic: WiFi not working
Message posted on 26 Mar 2025 02:40 PM
WiFi not working
WiFi keeps dropping in and out all day today every 30 seconds or so, no internet available for phone or tv app use. This has become a regular occurrence and the WiFi is completely unreliable
Message posted on 26 Mar 2025 02:42 PM
Re: WiFi not working
@emmadarbyshire
