Discussion topic: WiFi not working
This message was authored by: Km1281
WiFi not working
My router isn't working and the connection is not working
Re: WiFi not working
@Km1281
This message was authored by: ClouJ
this is all  u guys at sky  keep replying with its down for hundreds of people ive had loads of complaints off my friends that they cant get on the game cus sky internet is down and not working theres loads of reported issues in the uk right now Do something sky
@ClouJ
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services. Hundreds out of hundreds of thousands.
ight but check down  detector bro theres been over a thousand reports all across the uk about this  **bleep**ty broadband n when  i contacted  them they saying we have no issues in uk like bruh why  would  over a thousand ppl report an issue in different  parts  of the uk
