Discussion topic: WiFi not working
This message was authored by: Dee99123
WiFi not working
Hi my WiFi isn't working. Test have been run and everything is set up ok. This happens all the time at the moment, every single week!
Re: WiFi not working
@Dee99123
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
