Discussion topic: WiFi not working
Message posted on 26 Feb 2025 07:36 PM
WiFi not working
Hi, this is the third time this week it says my WiFi is connected when testing the connection but it's not. My tv won't load and my phone won't work on tv!
Message posted on 26 Feb 2025 08:05 PM
Re: WiFi not working
Does a reboot of your broadband hub at the mains help ?
Message posted on 26 Feb 2025 09:19 PM
Hi, i have done this, it been happening for over two weeks. Keep loosing connection and even now its only showing two lines and not three to be fully connected
Message posted on 03 Mar 2025 07:00 PM
WiFi not working
I am having the same issue I have had for weeks with sky! It says my WiFi is working buts it's not?
what do I do? Do I need to upgrade or get another broadband provider and this has become a joke now. Who can I call to get this fixed
Message posted on 03 Mar 2025 07:07 PM
@Ellis301
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
Message posted on 03 Mar 2025 07:09 PM
I don't have a sky land line can I have the number to call them please, I have done everything to fix it
Message posted on 03 Mar 2025 07:12 PM
@Ellis301
To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Message posted on 03 Mar 2025 07:18 PM
I'll ring them
now thank you x
