Discussion topic: WiFi not working
This message was authored by: Giovanna3
WiFi not working
WiFi is down. Have rebooted the router multiple times.
Re: WiFi not working
@Giovanna3
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
