Discussion topic: WiFi not working
This message was authored by: Z1000rider
WiFi not working
Two green lights and one red but test says all is ok?
Re: WiFi not working
@Z1000rider
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
This message was authored by: DH2384
Same problem. Done all test and it says everything is fine. But it's not working
