Discussion topic: WiFi not working in kitchen
Message posted on 26 Feb 2026 02:23 PM
WiFi is not always working in the kitchen
Message posted on 26 Feb 2026 02:44 PM
Re: WiFi not working in kitchen
@Cw271 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
