Discussion topic: WiFi not working!! Keeps kicking me out. I need for work and pay enough for my bill, shouldn’t happe
This message was authored by: EJG-
WiFi not working again and can't connect to sky boxes!
Re: WiFi not working!! Keeps kicking me out. I need for work and pay enough for my bill, shouldn’t h
@EJG-
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
@EJG-
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
