Discussion topic: WiFi not working 5ghz
Message posted on 03 Mar 2025 09:35 PM
5ghz seems not to be working how do I fix
Message posted on 04 Mar 2025 07:41 AM
Re: WiFi not working 5ghz
@ORed all current Sky hubs should broadcast a single dualband SSID what makes you think your hub is not doing that.? The 2.4G`Hz band has less range than the 5GHz band due to simple physices so devices further from the hub will only connect to that band.
Message posted on 04 Mar 2025 07:46 AM
Hub is saying it's enabled but neither of my wifi repeaters are picking up the 5ghz and both were yesterday. I have reset all devices. ( by also following basic physics and pushing the reset button 😉 )
Message posted on 04 Mar 2025 08:25 AM
@ORed while its possible the hub's 5GHz band output has failed its not a likely fault. Sky will swap a faulty unit if asked but before calling them I would check by funning a wifi analyzer app on a phone to rule out an issue with your WiFi repeaters. If you have a white hub they can use up,to ch165 which not all devices can use the black hubs use ch36 with a 80MHz bandwidth.
