Discussion topic: WiFi not woorking
Message posted on 03 Sep 2026 06:21 PM
WiFi not woorking
I've not had WiFi. Connection all afternoon I've turned the tv off and put it back but still not working the signal is very poor here I can't use laptop or anything as it says no signal
Message posted on 03 Sep 2026 07:33 PM
Re: WiFi not woorking
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
