Discussion topic: WiFi not woking
Message posted on 22 May 2025 10:00 PM
WiFi not woking
Had sky broadband installed today, internet worked for a while but has now dropped off. Have restarted the router but hasn't solved the problem
Message posted on 22 May 2025 10:03 PM
Re: WiFi not woking
What light are lit on the hub as this explains them:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 27 May 2025 08:31 PM
Re: WiFi not woking
Thanks for your reply.
All lights seem to go off and on randomly, mostly the internet light doesn't come on at all and the "voice"light is orange.
The internet will connect for a while and then disconnect a few minutes later. Very aggravating especially as only had it installed last week.
I have ran the check on the app and it says everything is fine, so will give sky a ring
Thanks again
