Discussion topic: WiFi not w
Message posted on 04 May 2025 06:28 PM
WiFi not w
I do not have 3 green light on my router the middle one keeps going amber
Message posted on 04 May 2025 06:40 PM
Re: WiFi not w
The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 28 Dec 2025 07:53 PM
Re: WiFi not w
Not working
Message posted on 28 Dec 2025 07:56 PM
Re: WiFi not w
@Stansfda
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
