Discussion topic: WiFi not fast or working
This message was authored by: Marg121
Message posted on 09 Sep 2026 08:06 AM
If I do fast.net it's shows 60mbps maybe 67 it used to be 250 and brilliant it's terrible now
Find out more
Message posted on 09 Sep 2026 08:10 AM
Re: WiFi not fast or working
@Marg121 So it is working or not? If you can do speed tests it would suggest your broadband service is working?
How are you doing speeedtests? Is this over wifi, what does the MySky app show the speed to the hub is?
