Discussion topic: WiFi not detected
This message was authored by: Wellmel
Message posted on 22 Feb 2025 09:56 PM
WiFi not detected
First the TV lost network connection and now mobile devices cannot connect even after resetting the router and lights showing green
Find out more
Message posted on 23 Feb 2025 07:29 AM
Re: WiFi not detected
@Wellmel think the hub maybe faulty but before calling Sky do a fullfactory reset which requires you to press and hold in the reset pin until the power led flashes which takes up to 20 seconds. Thay will definitely restore the default settings so the SSID and password on the label should work unless the hub is faulty. Pressing the reset pin and releasing early just rdboots the hub and doesnt reset the settings.
