Discussion topic: WiFi not connecting
This message was authored by: LaurenDixon
WiFi not connecting
I have ran tests on my wifi and it says everything should be fine but nothing is connecting.
Re: WiFi not connecting
@LaurenDixon
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
