Discussion topic: WiFi not connecting to sky stream
Message posted on 22 Aug 2026 09:56 PM
The service checker says our WiFi and broadband are fine but we can't watch tv on our sky stream it shows a picture then just freezes on every Chanel. ?
Message posted on 22 Aug 2026 10:11 PM
Re: WiFi not connecting to sky stream
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
