Discussion topic: WiFi not connecting to devices
Message posted on 02 Jan 2026 11:22 AM
I have been away and come back and now my devices won't connect to the internet, it's saying wrong password or no channel available, I have rebooted the modem and pressed the reset button and the problem continues to be the same
Message posted on 02 Jan 2026 12:09 PM
Re: WiFi not connecting to devices
@Janice40 is it possible someboody has changed the password while you are away? If it is you do nedd to reset the hub which requires more than pressing the reset pin in. On the black hubs keep the pin pressed until the power led flasheswhich can take 20 seconds. On the white hubs press the wps button in until the led flashes green which takes 30 seconds.
