Discussion topic: WiFi not connected
This message was authored by: Hayleylusty
WiFi not connected
My WiFi is down
Re: WiFi not connected
@Hayleylusty
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
