Discussion topic: WiFi not connected
This message was authored by: Kerry1309
WiFi not connected
Checks came back on but no wifi connection
Re: WiFi not connected
@Kerry1309
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (in this case Sky).
If it's still down in the morning use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
