Discussion topic: WiFi not been working
This message was authored by: Gila
The WiFi has been terrible for the last week. I've done a broadband test and it says 'good' but it's not true and the tv is constantly buffering. I'm constantly having to use 5G on my phone and disconnect from the WiFi. I'm not sure what I'm paying for at this point.
Re: WiFi not been working
@Gila
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
